Help Problem in Supertab flytouch3.Error the process android.process.acore has stopped unexpectedly
david36pt
I made already the root with Z4root and continues to appear the same message,
Error the process android.process.acore has stopped unexpectedly.
Another problem is super heat during using the tab with no charging connect in the back
Can somebody help me please
MODEL DISC010
ANDROID VERSION 2.2-20110529
KERNEL VERSION 2.6.32.9
BUILD NUMBER FRF85B
MODEL DISC010
BUILD NUMBER FRF85B
Did you do it so you can load tim's modded rom on it?
No time for diagnosis. Everybody got that problem.
Backup if you can. Unless just re-flash. And keep living your life.
hello,when i tried touch screen calibrate it just stopped,som i rest the apad and now Android.process.acore always show up, can somebody help me
as stated earlier do a fresh rom install. use tims new one 5a i thing its called. format the sdcard and install it with the power cable connected.
I had this problem with mine right out of the box as well. As stated, reinstall the firmware. I also recommend Tim's 5a ROM, which is very nice, and also fixed a screen brightness issue I was having as well as rooting it. You can download it here: SuperPad2 Flytouch3 Hybrid Tim Rom
But the thing is if he wanted to load Tim5a he would not need to root it. Just throw the 2 files in the sd card and startup the table and voila.
