Help Problem in unstalling an app
I have installed an app from 9app.com now i want to unstall it but i couldnot do that....because in application manager all the option are disabled only for this application. Please guide
Can you check to see if the app is a Device administrator (Settings -> Security > Device administrator)?
If it is, un-check/de-select it and then see if you can do the uninstall from Settings -> App.
Hopefully this is not malware...you know it's dangerous to install apps from unknown sources (i.e., outside of the major play/app stores)?
