Problem inputting text into my DHD
Firstly before being rude and going right into my problem, Hello I'm new here and think it's a brilliant forum and I have had a quick search to see if this has been answered before but I couldn't see it, now to my problem!
I got a DHD about a week ago and love it, took a bit of getting used to with the battery but managed to get a decent level of usage out of it but now I'm having a problem when entering text. This isn't just when sending text messages its anything that requires text. When I push a letter it shows very briefly (maybe half a second) then deletes it and the cursor returns to the original starting position. It's like the delete part is stuck down. Very annoying.
I was out at the pub last night and think theres a chance Ive maybe done something after a few beers. Problem is I have tried settings etc but can't seem to fix it. I called Orange and they werent very good, they offered me a new handset or to try master reset which I really dont want to do as Ive only just got it to my requirements and don't fancy having to start all over again.
Any help will be greatly appreciated!
Have a look around the market. You can get some pretty good replacement keyboard apps, and some with bigger keys which may help your accuracy problem.
I used to have a great one, but I can't remember what it was called! Had brilliant big querty keys
The problem is though that I wont be able to even search on the marketplace. Anything being entered deletes automatically even when pasted onto it.
Ah! Sorry, I misunderstood your problem. I thought you just had fat fingers!! ;)
Send it back as faulty. Don't tell Orange you "might have done something whilst in the pub"
Try reseting your phone, maybe it'd just a temporary glitch and will hopefully be resolved after a quick "hold down of the power button" reset ;)
