I have an international GNEX. It was bought in June but when I discovered it was Yakjuxw I rooted and installed the stock ICS Yakju using the nexus root tool kit. I then got the OTA JB 4.1.1 update and all was good.
Today I got notification of the 4.1.2 update but it will not install.
I get the error:
Installing update...
installing samsung updater extensions
Verifying current system...
file "/system/vendor/lib/libsec-ril.so" doesn't have any of expected sha1 sums; checking cache
failed to stat "/cache/saved.file": No such file or directory
failed to load cache file
script aborted: assert failed: apply_patch_check("/system/vendor/lib/libsec-ril.so", "2add52e76e1d55d7a65639c5ff10fb7d36b00412", "3a60da9ea4de9bdf4368fb5f0d7f067b1fbb4ff4")
E:Error in /cache/24a9a760f32e.signed-yakju-JZO54K-from-JRO03C.24a9a760.zip
(Status 7)
Installation aborted.
anyone know what's going on?
I get the error:
(Status 7)
