Help Problem Playing Movies
erijacob
I'm having trouble getting movies to play on my Evo. I FINALLY came across one that will play in the gallery.
Here is the MediaInfo for the working video:
General
Complete name : C:\User\Videos\A Bug's Life [En - Ro] DvDrip_H.264.m4v
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 841 MiB
Duration : 1h 30mn
Overall bit rate : 1 293 Kbps
Encoded date : UTC 2009-11-18 04:27:13
Tagged date : UTC 2009-11-18 05:30:52
Writing application : HandBrake 0.9.3 2008112300
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1h 30mn
Bit rate mode : Variable
Bit rate : 1 000 Kbps
Width : 718 pixels
Height : 432 pixels
Display aspect ratio : 2.35:1
Original display aspect ratio : 2.35:1
Frame rate mode : Variable
Frame rate : 24.988 fps
Original frame rate : 25.000 fps
Minimum frame rate : 16.667 fps
Maximum frame rate : 34.067 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.129
Stream size : 650 MiB (77%)
Writing library : x264 core 65
Encoding settings : cabac=1 / ref=5 / deblock=1:2:2 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=1.0:1.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-4 / threads=6 / nr=150 / decimate=1 / mbaff=0 / bframes=6 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 1h 30mn
Bit rate : 160 Kbps
Maximum bit rate : 208 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Stream size : 104 MiB (12%)
Language : English
Tagged date : UTC 2009-11-18 05:30:50
Audio #2
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 30mn
Bit rate : 128 Kbps
Maximum bit rate : 165 Kbps
Stream size : 83.3 MiB (10%)
Language : Romanian
Text
Format : Apple text
Codec ID : text
Duration : 1h 30mn
Bit rate : 1 bps
Stream size : 898 Bytes (0%)
Language : English
___________________________________________________________
Now can someone tell me why this won't work? The image for the movie correctly shows up in gallery but when I click on it, it says Sorry, this video cannot be played:
General
Complete name : C:\User\Videos\She's Out of My League 2010 720p BRRip H264 AAC-GreatMagician (Kingdom-Release)\She's Out of My League.mp4
Format : MPEG-4
Codec ID : isom
File size : 1.62 GiB
Duration : 1h 44mn
Overall bit rate : 2 215 Kbps
Encoded date : UTC 2010-08-08 11:05:12
Tagged date : UTC 2010-08-08 11:05:12
Video
Format : AVC
Format profile : High@L4.1
Format settings, ReFrames : 7 frames
Codec ID : avc1
Duration : 1h 44mn
Bit rate : 1 896 Kbps
Maximum bit rate : 11.9 Mbps
Width : 1 280 pixels
Height : 544 pixels
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.114
Stream size : 1.38 GiB (86%)
Title : GreatMagician She's Out of My League
Writing library : x264 core 98 r1649 20cbe10
Encoding settings : cabac=1 / ref=7 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=22 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=24 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=48 / rc=2pass / mbtree=1 / bitrate=1896 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=31250 / vbv_bufsize=31250 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=none
Tagged date : UTC 2010-08-08 11:16:47
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 44mn
Bit rate : 317 Kbps
Maximum bit rate : 380 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Stream size : 237 MiB (14%)
Language : English
Encoded date : UTC 2010-08-08 11:15:29
I'm trying to figure out what settings actually work! What is it about this second movie that it won't play?
Update: Opening the 2nd video in RockPlayer, it will play the video but it is EXTREMELY choppy and unable to be watched. File seems corrupt (even though plays fine on computer)
I also tried renaming the 2nd movie to .m4v like the first one which works, but that did not do it either.
Meridian gave the same error as the gallery, but all of my other media worked fine in it
I don't use handbrake, I've used Squared 5 - MPEG Streamclip video converter for Mac and Windows for years (just tossing that out there).
I use that and just ensure that anything I've transcoded is H.264 (equivalent of MPEG4 Part 10) - and I'm not sure how that will change anything for you, because your video portion is already tagged AVC.
But what will change is that your .mp4 file - while it contains the right idea - is a different _container type_ -- and when tossing about formats, it's really a combo of container + codecs, so renaming that MPEG4 Part 14-type file to the MPEG4 Part 10-type file name isn't fooling anything.
Thanks for the tip. Was having a terrible time getting a converted video to work on my phone. Only problem with Squared 5 is it won't convert .flv so I have to use a two step process. Any suggestions for that?
