I've had my Infuse for 2 weeks now and I was just sent my first MMS message. It says downloading, but it has said downloading all day and I still can't see my picture. Any solutions? Thanks.
I'm having the same issue. Both sending and receiving. Though all came in or sent finally except for one that I had to ask to be emailed, and resorted to. Which is sad really.
Curious, are you also using any battery saver programs? I heard it can be the problem and I really didn't get any MMS till after I installed mine.
I'm not using any battery saver programs. I fixed the problem also. Go to your message settings and turn your MMS settings to not download automatically. This solved my problem right away.
