Help Problem registering yahoo email
reesheey
Hi there,
I just got my Desire Z and been having good time with it. I have registered all my email addresses such as Gmail and Hotmail but I cant seem to register Yahoo mail..it says cant verify username and password. I've done this many times and I'm sure of my username and password..anyone can help me over here..thanks..
Reesheey
I think some people have problems using yahoo with the default email apps. You could try the yahoo app, or combine all your emails with k9 mail.
Hi there,
Reesheey
Not sure if you have seen the information below, if you havent, then try it.
-Go to "Mail", select "New Account"
-select "Other (POP3/IMAP)"
-click "Manual Setup"
YOU WILL SEE "INCOMING SETTINGS" AT THE TOP
-in "Protocol", select "IMAP"
-in "email address", key in your yahoo email address in full
-in "username", key in your yahoo email address in full
-in "password", key in your email password
-in "POP server", key in "imap.mail.yahoo.com"
-in "security type", select "SSL"
-in "server port", key in 993
CLICK NEXT YOU WILL COME TO "OUTGOING SETTING"
-Click "login required"
-in "SMTP server", key in "smtp.mail.yahoo.com"
-in "server port", key in 465
Click NEXT and you should be able to add your yahoo account in your push mail.
Hope it helps...cheers
