Running 2.5.0.1 Premium and every function I try to use generates this message: "An error occurred while attempting to run privileged commands!"
Sucks to pay for something and can't use it. Thoughts before I uninstall it and return it to the Market for a refund?
Give me a little bit more info here.
I presume you are on a Droid 1, with the FRG22D build...?
You got ROM Manager recently, installed it, then when you open ROM Manager and try to run any function it says that?
I presume you have gone through the root process and have achieved Root Access on the phone?
Let me know.
Yes. Rooted Droid 1 running FRG22D. I get the error when I try to run the following functions: Flash ClockworkMod Recovery, Fix Permissions, Flash Alternate Recovery. When I attempt to use Reboot into Recovery, and Install ROM from SD Card it simply stalls. It doesn't lock up, it just doesn't perform the requested function.
