PhoneMan93
i flashed my icon theme pack and all worked except for phone.apk it didnt change a bit, and ive looked into it and cant find out why. Any help will be greatly appreciated
the icon is in contacts.apk
is it called the same thing?
and how do i edit the .zip show it can say what i want it to and not WP7 bye bloodawn lol
thanks for the flashable zip btw
yea
edit the updater-script
do i have to use ubuntu for that?
once again Thanks for helping me blood youve been a lot of help to me and a huge contributor to this community
aww man i guess there is a xml file somewhere that keeps changing it back to the regular phone, do you know if that is correct?
nah. you can open it with notepad++
your icon is named ic_launcher_phone.png right? you put it in drawable-mdpi? if you did both of those then it should work
yeah its named that and i delete the green one and change it for mine and close when i reopen its green again?
when you opened what? how are you doing this?
are you adding the icon while its decompiled with apk manager then you recompile it and the icon didn't change? if so its cause your not deleting the old icon from the keep folder during the compile
if all you want to do is add the icon just use 7zip and drag and drop the icon to the folder in the apk
