I recently bought Galaxy i7500 and have problems
My device hafirmware 1.5 and Baseband version: I7500XXII7
I enabled the usb debug mode and when I connect the phone to the computer, it says new hardware found but then it cannot find the driver.
I point it to the Samsung directory but it says "Windows was unable to install your Unknown device"
In the meantime in NPS it gives me a number of messages ->
It shows a handset icon with GT-i7500 and two mass storage icons.
A popup says "GT-i7500 only supports the following features: Features supported: Update Device"
Another popup says "Other features| Android"
If then I select the "Update" icon and then I select GT-i7500 from the dropdown I get --> "This device is not supported..."
If I try to click on the handset icon, I get --> "Unsupported device"
If I try to click on the mass storage icon I get ---> "Insert the disk into the H drive" !!!
Does anyone knows how this works? Why is it so complicated?
- in connecting it with my computer for transferring music files and photos and
- in trying to update it.
- Import an image to PC
- Import amovie to PC
