Problem w Evernote -- no SD card
My TB screen got smashed so I got another one via the insurance. I downloaded Evernote but can't login because it says I must have a SD card. I didn't have a SD card with the previous TB and Evernote worked fine. Any ideas?
Thanks
Are you sure you didn't have a SD card with your previous phone? All phones normally come with a SD card automatically. Mine came with one and when I switched from one phone to the other I had to take out SD card and SIM card as well. The SD card is pretty hidden behind the battery area.
If you still have the phone that got smashed, you may want to make sure by looking in it to see if the SD card is there or not. If not, I'd call Verizon because you should have been given a SD card when you purchased the phone.
