Wow, am I the only person who hasn't had any major problems with this phone? The only issue I've had is some lag while playing Angry Birds, but I knew this phone doesn't have the best RAM. Other than that, not a single self reboot or any other issues. I will say that right out of the box I put in my 16gig micro SD card from my Samsung Fascinate. Although I don't think that had anything to do with it. So yeah, I've had this phone for over a week now, but will keep you updated if anything should arise![]()
There are some dramatic differences, though, so tread lightly with comparing information on the two phones. The recommendation to upgrade your MiniSD card is one that seems to work for a lot of people. If you can afford to upgrade the MiniSD to at least a class 4, you should -- it's fixed my issues entirely.
I already tried that.. I actually hedged my bet by going class 6 (as pointed out in an earlier post)... didn't work..
It is doing it about 3 or 4 times a week... . and is totally random.. almost never the same activity.. once while playing a 'parallel kingdom' game. once while doing nothing... once while in a call.. once while browing.. etc. etc. no common thread it appears... I wonder how many times it does it when I am not looking/using it?
since it does it on every rom flashed i'm going with it's a hardware problem.Like I said mine used to do it and stopped so there's an underlying issue somewhere
This really is a great phone, don't knock it crudeboy. However I suggest exchanging it for the same one, it's a problem across several other optimus models and it's dodgy flashing cm7 fixed it entirely for me as stated.
I picked up a 4gb class 4 SD a couple of days ago and it seems to have helped out quite a bit. I've had a couple of reboots but nothing near the amount I was having a week previous. I am getting what seems like an odd amount of Force Close notices, however, but either way I'm not quite as cranky about the issue.
I tried carrying it back to my local Cricket store and was told that there wasn't really much they could do without seeing the problem firsthand. Of course, while waiting to show them the phone worked just fine.
I had the Droid before and feel like this is a real step down!
