Has anyone seen a problem when you are viewing a picture while the screen is horizontal and you select "Share", the options where to share from does not fit the screen and is cut off on the top?
The workaround I use is to select one of the options shown where I can re-share, and then open the Share menu from that program which has a standard scrollable list.
