Help Problem with ADW Launcher
fortecasa
Hello! Greetings from Greece!
I had a problem when I installed ADW Home Launcher. When I installed it and opened it, the main menu doesn't have any buttons for calls or messages. I thought they should be there by default. What can I do? How can i make them appear so as to use it? Thanks in advance!
I have not used ADW in a while, however from memory you would either press and hold on the bar where you want to add such a shortcut and choose the relevant one or press the menu button from the home screen and edit the launcher settings from there.
