Hi there
Last week, I bought a LG Optimus One (P500), and so far I like it a lot! It came with Froyo, but I have a little problem with it..
The FM radio is accessed from a widget which lies on another screen than the home screen. When I use it, it works just fine, but when I turn it off the problems begin! I turn off the radio, unplug the headphones, go back to the home screen and lock the phone. If I unlock it right away, there is no problem and it just shows the home screen, but if I wait, say, 5 minutes, the phone will go right to the screen of the FM radio widget when unlocked instead of the home screen!!
I tried going to the task list from where I closed all running programs related to the FM radio. That did not do the trick. The only thing that helps is restarting the phone.
Does anyone know what the problem could be and how to fix it? It is getting really annoying.. I have the latest update.
Thanks a lot in advance!
Best regards, Rete
Best regards, Rete
