Help Problem with auto correct on droid 3...
When I'm typing something with the keyboard the auto correct bar shows up on the bottom of the screen. If I exit out of the application the bar still stays on the bottom and doesn't go away until I close the keyboard and turn the screen sideways.
Is anyone else having this issue and if so how did you fix it?
i'm having that problem too, make sure you press the back button before exiting out of the messaging screen and it will go away... i'm sure it will be fixed with the next update.
