MikeAndSal
I'm sure that I can't be the only person to have this problem, but I'm unable to stream music to a bluetooth speaker without the music cutting out every few seconds. Doesn't matter if I'm streaming from the internet or my PC, it just fails to play correctly.
For example, I can use Tunein Radio app to listen to a radio station and it plays fine via the internal speakers. Connect to the bluetooth speaker and it will cut out within a few seconds - TuneIn is buffering at this point.
If I play music held on the Nexus itself through the speaker then there's no problem - it's only a problem when streaming.
If I use Tunein on my phone to stream to the bluetooth speaker then it works fine - no buffering, streams perfectly. Therefore not network interference between bluetooth and wifi?
Phoned Google - they couldn't help but they did agree to send out a replacement Nexus - same problem.
Anyone got any ideas on how to fix this problem? One of the main reasons for buying the tablet was to stream music from my PC, but it seems incapable of using bluetooth and wifi at the same time.
Any suggestions gratefully received!
