Root problem with bootstrap and rocko 3.0 locked
IzzyDez
so I finally got to flashing a rom. i flashed rocko's 3.0 locked but i kept getting force closes for a phone process and my settings wouldnt work so i recovered back to stock. The recovery however kept freezing at a file called 1336834611.tmp so i figured that made it impossible to backup my apps. Now i have to re-download everything -.-
the question is was my backup corrupt or should i use something other than bootstrap to make backups?
the other question is i see that rocko 3.0 seems to impact battery a lot so is there a stable and great working version of rocko for my mopho with a locked bootloader?
What steps did you take prior to actually flashing Rocko, i.e.- formatting cache, data, etc? I ask because I ran into a similar f/c problem when I don't do exactly the steps below for Rocko. I've been using Rocko for a few weeks now and haven't noticed hardly anything glitchy.
As far as the backup, I also use bootstrap recovery so it sounds like you were doing it correctly.
Here's the site for those steps that I've got to do:
{ROM}(ROCKO)(EternityProject)Locked&unlocked(03/23/12 new 2.3.5 test) - Page 26 - xda-developers
Also on page one of that same forum is the version of Rocko that I'm successfully using. Hope this helps.
i don't think i cleared my data that is probably why...and how exactly does sbf work? cause it seems the same as a factory reset
hopefully this time nothing force closes
