problem with calls
reader
hello
I have UK Lycamobile and Samsung Galaxy Note 2
some day, I dialed by mistake some numbers, asterisks and hashes, which probably sent a code to the network and from then each time I call someone, my number appears as "private" in his screen
can you tell me please how to reverse this?
thanks!
Have you tried doing a factory reset? I'm not sure if this will work as you gave it a hardware program code from the sounds of it so I would stay on the provider and insist they help after all thats part of what you are paying for.
