If that is the case clockworkmod recovery was not installed properly. In most cases this is because the stick.zip was not applied. Try reflashing cwm and as soon as odin goes to reset, hold volume up and the power button. This will take you to where you can install the stick.zip. Once that is done, reboot and cwm will always be there for you.
