dcooterfrog
new to android. not smart phones.  clearly something is not right.
downloaded clokwork and flashed the recovery.
if Itry to boot into recovery right after flashing it works.
if I try to boot into recovery after that reboot from rom manager... i get the android exclamation point for a moment and then normal reboot
if I try to boot into recovery send end menu i get the android exclamation point and reboot then normal boot.
if I reflash the recovery and reboot into recovery from rom manager it works.
if I try to do subsequent boots into recovery android exclamation and then reboot again and normal boot
i also removed clockwork and reinstalled it.
i flashed the other recovery amenra and got the same kind of results... except in amenra I could not do anything and I had to pop the battery to reboot. none of the hard keys moved though the menus
