Root Problem with cm9
cmayes1
I am currently running the Fuzion rom from 2fastroms. I downloaded the cm9 and gapps and flashed them. My phone just stays stuck at the very first screen of bootup, doesn't even make it to the htc animation. I am rooted and S-OFF. Any clues as to what is happening. I tried to copy the boot.img from the cm rom using fastboot also but it fails saying remote not allowed. I've never had problems before....
You should not really have to flash the boot image seperately if you're s off. Maybe you have a bad download of cm9?
Other than that,have you asked in the cm9 thread?
Awsome! Glad you are sorted and thanks for posting your solution. Wat recovery did you upgrade to?
