Help Problem with contacts after ICS
taralej
I own a samsung galaxy s2 GT-I9100, about a week ago I upgraded to ICS with Kies and as I was adviced to do I reseted to factory defaults, but still I am experiencing a lag when opening contacts, the interesting part of the problem is that everything else works more than better for me. I have currently 165 contacts which contain only phone numbers. Synchronizing is off for my gmail and facebook and still the lag continues.Upon opening contacts I have about 4 sec delay.When the app is opened, lag appears when I am trying to dial a number.
Any ideas ?!
Quote:
Originally Posted by ironass
Hello and welcome to android Forums taralej! :)
Sorry to learn about your Contact problems.
Just a few questions...
1. What version of ICS are you on?
(Dial pad, type in... *#1234# and give the first 3 lines of information)
2. Have you made a back-up of your contacts?
(Contacts > Menu > Import/Export > Export to SD card )
3. Does this happen every time you open them or just the first time after re-starting?
4. What contacts are set to display?
(Contacts > Menu > Contacts to display )
1.
PDA: I9100XWLP7
PHONE:I9100XXLPS
CSC:I9100OXXLPH
2. I can't remember doing such a thing I made a backup only to my PC. If I did such a thing how will this bring the current problem and how to fix it ?!
3.If I restart the phone, and start clear, the first time I open contacts the delay is there.After that there is delay only if I close the app with task manager.
4.Contacts to display is set only to phone.
The problem according to me is opening the application for the first time, only then it delays.Also the problem I mentioned above about delay when dialing appears randomly.Even if I delete all my contacts there is still delay of 3 seconds on opening which leads me to the conclusion there is something wrong with the app everything else is just working great.
