Help Problem With Desire Calendar
Hi , I sync my work rosta via outlook to my desire no problem. I always save my data in outlook with no reminders,but I use my desire as my alarm clock too, and could scream at midnight sometimes when it notifies me (in airplane mode" of my soon to be starting shift at 4:00am :(
I have just gone through the rest of this months shifts on the desire , and selected "add reminder" then selected "none" but there must be an easier way to stop the desire keep reminding me of events i'm trying to get some sleep for :p
Calendar (stock calendar) > settings > reminder settings
In there you can turn off all noises and vibrations, which is what I've done. Simply because I didn't want to go into every sync'ed event and disable alarm. Bit of a nuisance, but better than the alternative!
And even though alerts are disabled, it'll still pop up on screen to let you know that you have an upcoming event.
I am using Locale with a timed profile (2200 - 600) and "orientation = up" condition to mute my phone for anything but alarms an incoming calls
works like a charm ..
D.
Same issue for me- it's driving me potty. I can't switch off my reminders as I need them. I stupidly just want it to work as it should!
