Help Problem With Dialer
fydave
Hey errybody,
I've noticed this problem on both of the Thunderbolts that I've had. I have a few customization applications installed: Minimalistic Text, Extended Control, Beautiful Widgets, LauncherPro, Circle Battery, and maybe one or two more.
The problem I noticed on both phones which I didn't on any other phone I installed these applications on to is that when I go to the dialer now it won't display any of the recent call log until I type at least one number in and erase that number. Once I do that it'll display the entire recent call log like it should but until I do that it simply shows me the dialer with a blank screen as if I haven't made any calls.
I was wondering if anyone might have any ideas as to why this is happening?
Thanks in advance! :]
Others including myself were experiencing the same problem. I don't quite remember the solution. I think it involved deleting the People short cut on your home screen and then adding it again.
If you do a search or check some of the older threads I'm sure you will find the solution.
