Problem with Google Now
blarelli
Hey guys, I'm having a bit of a problem with google now after I search for something. It loads up the regular search results and I can bring up the images results, but some of the time the links can't be selected. It acts more like an image than a website. Any ideas?
I think(?) Thats just how Now works man, if it can show you a card, it will, if not it will show search results. You can switch Now off and use the old Search :thumbup:
Even when it finds a card, I get the option for both
Not the card portion of google now, that works just fine. If I use the search bar at the top of the screen or above the cards inside the app itself it performs the search but doesn't allow me to click on any links.
