Problem with GPS dropping signal
Run GPS Status (free at the Play store) and see what's really happening. (There's no "GPS signal", there are 24 satellites, and your phone gets a separate signal from each one that's in view.) See if you're losing all signals (probably an intermittent antenna connection) or just a few (bad firmware) or what.
The GPS stopped working in my 2012 too. I had sat on it, and the pressure bent the pins that connect the main board to the GPS antenna which is built in to the back of the casing.
I had to pop the cover off and gently bend the contact pins back up. GPS worked flawlessly after that.
