Originally posted accidentally in 'introductions'. My bad. Quote:
"i7500 refuses to load images. That sounded a little bombastic, sorry.
My O2 UK i7500 will not load pictures from the gallery, when changing wallpapers (I basically can't), Picture Frames widget, even Astro's built in viewer returns a message "(whichever activity) in (application whichever -usu. camera?) has stopped responding." Force close.
Baseband I7500XXIH6
Kernel 2.6.27 hudson@andy#1
Build 76XXCSDCBALUM6375
Any ideas much appreciated! I suspect I may require some sort of firmware update, amirite? I'm a complete novice to Android.
EDIT: Should mention that I've been lurking on this problem a wee bit, and the only similar problem was solved by installing a different SD. I've done that, still no luck
Baseband I7500XXIH6
