Problem with mounting SD CARD!!!
wolf1910
Please I need urgent help while I boot my Acer E Liquid, it doesn't read any kind of SD cards.... can i have any help?
Try running a USB cable from your droid to your PC. Enable USB file sharing on your droid. See if a new drive appears in your PC.
Or, unmount the SD from your droid. Remove it and plug it into your PC/Mac, see if that works.
If neither works, the SD card may be funky. If they do work, your droid is reading funky and may need a factory reset. Hard to tell from here.
Hello wolf1910! I merged your other thread with this one in your device forum:)
Try as jefboyardee suggested and also you may have to format your card and try it again:)
guyz, the problem is that all the SD cards are working on other devices.... Maybe do I have to format them on FAT 32 or NTFS?
