I'm running the Synergy Rom, it's been working fine since I installed it. But the other day I've started to have a problem where when it's plugged in the USB the SD card isn't accessible. I've checked and it's not set for mount SD mode, it's just charge. I've rebooted and used a task manager to see if something was running in the back ground that might be causing it. I'm not seeing anything.
I'm not even sure what else I can check/do here, so any suggestions would be great.
