Help Problem with return key and menu key not working
Wetpatch
Please help had this phone for 1 day and today it went crazy in the charger now the return and menu button wont work on the bottom
have removed battery reset did a reset and yet still not there
Were you using the charger that came with the phone or a third party or after market charger? If you are using the charger supplied with the phone, take the phone back and get it replaced. If you are using an after market charger, it is possible that it caused the problem. Of course, you can still take it back, but in the future make sure you use the supplied charger or another one designed for the phone.
