Root Problem with Rom Manager
rjd262
I asked this in a different thread, but though I should make a new one for this.
I just rooted my phone using SimpleRoot OTA, and now I'm looking to install the Damage Control ROM. I'm new to all of this, so I might be missing some steps here.
I installed ROM Manager, and attempted to use it. It prompted me to flash clockwork, so I hit the ok button and away it went. It came back with the error message: "An error occurred while attempting to run privileged commands!"
I'm stuck at this point. Does anyone have an idea as to why this is happening?
Go to Settings > About Phone > Software Information
Is your "software number" 1.47.651.1 ?
This happened to me after doing simpleRoot and when I checked my version number on my phone it was not 1.47.651.1, it was 1.17.x.x something like that. I'm not sure what I did wrong as I followed the guide as close as possible. It could have had something to do with a file Unrevoked had left behind on my SD card.
So to remedy it I did the "second part" of the simpleRoot which took me about 5 minutes and was almost too easy. The link is here.
http://forum.xda-developers.com/showthread.php?t=715915
After doing these instructions I tried ROM Manager and checked my software number and it was now correct and everything was perfect.
Yea no problem, make sure to let us know if it worked. I was super anal about unrevoked leaving stuff behind so I formatted my SD card (fat32) before I did step two so the only thing on my card was one file :)
I just finished, and I'm loading Damage Control as I type this out.
I didn't go as far as formating my card, but I did uninstall unrEVOked. I had to do the whole process on that page you linked before it would work, start to finish.
Thanks again!
