Root Problem with Root Explorer..
ska.t73
Android Expert
Ok quick question... I can't seem to be able to re-name files in my /system folder. I am tring to do this in Root Manager and it is telling me that the permissions are set to read only... however if I try to set the permissions in Root Manager it tells me I can't do that...
Anyone have any ideas?
(note it does the same thing in Astro, but i can't figure out how to try and set permissions in Astro...)
lol yea thanks... I thought I had that set, then I realized that you have to set it for each sub folder you go into...
Thank you again for the reply it is all fixed now :)
