Help Problem with sense calendar widgets
StuartTheFish
I'm using the 4x1 size sense calendar widget as it looks nicer than the 2x2 android widget, but for some reason it doesn't show my events if they're within two days away. The android one shows them right up to the actual day of the event before disappearing on the day itself, so is there any reason why the sense one drops events when there's still two days to go? I can't find any options where I can change it's settings...
I found the Sense widget didn't show the next appointment I expected. I didn't spend much time trying to resolve it as someone suggested Smooth Calendar which displays the next three events which I find much more useful. Very small and just works.
Can I also suggest "Android Agenda Widget" its free and there are about 10 different sizes and you can customise just about everything. I switched from the HTC widget and haven't looked back since.
