Problem with TB restore
ma2
Member
Well I finally built up the nerve to go for it and using Chainfires excellent Mobile Odin I now have JB 4.1.2 on my I9100.
I am now trying to restore my apps settings; however when I go into TB Pro; Backup/Restore/Batch/Restore its not seeing my TB backup on my external SDcard, all restore options are zero.
Am I missing something ?
John
Using a file manager, move your Titanium Backup folder from External SD to Internal SD and see if that does the trick.
Did you store your back up on your external SD card? If so it could be TB cannot locate it as JB now sees the external SD in a different location to ICS. I'd use a file manager to cut and paste the whole ofTB fgolder to your internal SD.
I'm not sure I'm right but it can't hurt to try.
Thanks chaps but I checked and I already have a copy of my TB Backup folder on my internal SD, checked properties and it all matches ok, contains all the .properties; .tar.gz and .apk.gz files.
I installed TB Pro from google play; was that correct ? I notice that there is a TB .apk in my TB Backup folder; should I have installed that instead ?
Also before I flashed I also created a TB update.zip called TitaniumBackup-5.7.2.zip; is this any use ?
Think I might have cracked it, I went into TB menu/preferences/backup folder location and rechecked my backup folder, bounced TB and restore apps all appeared.
Now restoring settings, sweat off, thanks for quick replies.
J
