Help Problem with the display and shorcuts.
Exidrion
Hey everyone, unfortunately I can't find my USB cable for my DSLR so I'm going to try and explain my problem textually and hope it's clear enough to illicit help.
When I create a shortcut on my home screen, and the application's (or what have you) name ends with a vertical line I can't really make out the end of the apps name, it's kind of blurry and dim-like, looking "cut off."
Examples would be like Angry bir*d* or Flight Contro*l* etc.
It's not really a deal-breaker, but I'm the kind of person who let's little things like that drive me nuts. Does anyone else have this issue, or a solution? Hopefully I don't have to send it back to the UK for a replacement.
Is this not because there is only a certain amount of space under the icon so that longer names end up being cut off? Personally I would use launcher pro rather than the stock touchwizz as this let's you edit the name under the icon or remove it altogether if you wanted
Yeah I'm starting to realise that's what it is now, because when I put "Gmail" on the screen it was fine. Pretty bad design flaw if you ask me, it looks terrible.
It's only a design flaw on the developers part. It's the same with iOS. There's only a certain amount of screen space that the app takes up and same goes for the name.
