Concker
Hello!
I will try keep short so well:
The problem is that after i upgraded my computer with new motherboard, cpu and ram, and did a clean install of Windows 7 @ 64Bit i have some issues regarding connecting the HTC Desire to my computer.
The problem is that when i connect it, it shows up as mass storage device but when i try to enter it, it says that it cannot be opened.
The strange thing however is that if i plug in my phone, then restarts the pc, it will work properly, but asoon as i disconnect the phone, and then reconnect it, the same issue, Cant accses the phone. And restarting the pc for everytime you want to copy some files to the phone is annoying.
So some basic info about the phone and computer:
The phone is a HTC Desire, that is rooted and uses RCMix HD room, (dont remember the version)
The Pc's specs are:
Motherboard: Asus P8P67 Deluxe.
Cpu: Intel I7 2600k.
So i have tryed the following to adress the issue:
Tryed diffrent cable's
Tryed install, and uninstall HTC Sync like 100 times.
Deleted the android phone driver, then reinstall.
Try to update the driver (Say's newest are installed)
Tryed all my USB Ports, including USB 3, and 2 ports.
Changed drive letter of the mass storage.
Rebooting phone etc.
I have set it to when i connect the phone it does autmaticly go into mass storage device, and i have "hid the message".
Also tryed the phone on 3 other computers, and works perfectly then. No need for HTC Sync or anything. Pop's straight up. But on my main computer i need to plug it in and restart everytime to get into the sd card...
I have however not tryed format the SD Card, but i highly doubt the problem is there since it works on every other computer without problems, to me it sounds like a driver problem, but why does it work when i connect the phone, then restart the computer, and then all of a sudden dont work if i try to disconnect it and reconnect ?
Im running out of ideas here so if you been having this problem, or know some sort of solution it had been superb!
Regards Daniel
The Pc's specs are:
Regards Daniel
