Help Problem with wallpapers, graphic glitch
Shibui
Hello, I'm having a problem that I cannot seem to find any info on. With certain wallpapers I get a very odd glitch, this includes live wallpapers. See the attached pic.
I used one of the stock live wallpapers. If I switch to certain other images it seems to be fine. I can't seem to find a pattern. As well I use perfect viewer to read comics and the same thing happens if I use its wallpaper function.
Any help is appreciated. Thank you.
Is your tablet running 5.1.1? I had a similar graphics glitch with 5.0.2, although mine was black and gray bars after I'd exit an app. The problem went away after flashing the 5.1.1 factory image.
