Problem with Wi-Fi connection
michele65
When i acivate my wi-fi connection i can see all the wi fi routers available and i can connect to them. The problem is that when i open my browser or other application that use internet i cannot navigate....and i don't see any page on the web......The wifi appears connected....i have tried with a router where the ip is automatically assigned and one where i have to enter manually all used address but the problem is the same.....
My Xperia configuration is:
Firmware Version:2.1-update1
Kernel Version: 2.6.29
Build Number: 2.1.1.A.0.6
When wifi connection is stopped i can navigate witout problems...
Thanks
Installed, but it seems the problem is still here.......I activate wifi, open the browser, the first page i search is ok, then stop.....With wifi fixer i see that it restarts wifi so the page i search is loaded but not with wifi........when wifi is started i can't navigate....
But in my case with out WIFI FIXER, By default I have no problems in using WIFI application as of now atleast. You are right, when you install wifi fixer it constantly reboots your WIFI application, I saw it in my mobile also, so Uninstalled!!!
Similarly I have problems with micro phone while using skype app, I can hear incoming voice , but other end they cannot hear my voice. made several attempts to fix it with no success.
I understood that, Xperia series have common manufacturing hardware defects with WIFI and Microphone devices. probably you may need to exchange your mobile with a new one if it is in warranty.
I have made new tests and i have discovered that the wifi connection runs witout problems with wifi lan not protected....free....the problem in navigation is present only when i have to enter the password to access the lan....even if i insert the correct key navigation is not possible...
