Root Problem with xtrSENSE and Bluetooth?
ksyrium
I flashed xtrSENSE (my first custom ROM btw) a couple of days ago. As many others have said, things have been just fantastic. It's really like having a new phone. Anyway, today I came across an issue which I doubt would be related to the ROM but I don't have any other ideas.
Once in a while I use a Bluetooth headset. When I tried today, it would not work. It used to work without issue with my stock 2.1 OTA ROM. When I tried it today, Bluetooth would activate on the phone but the headset would never successfully connect. I put the phone in discoverable mode but I never saw the headset appear in the list.
I'm not sure where to begin looking but I thought I would ask here to see if anyone has some suggestions. Thanks.
Ok, problem solved. I had to put the headset in a special mode in order to make it visible to the phone. When I did this, it started working again. I now know that this is something that does not get restored by the backup. Thanks anyway! :)
I'm having this same issue. Flashed xtrsense 4.6 last night, it's great except that i can't connect my bluetooth. I don't have a way to change the mode of my headset. What do I do?
After flashing a new ROM you must pair all BT's again.
This.
Also, FWIW, I recently installed xtrSense 4.6 and paired and used my BT headset no problem (after pairing it, of course). So, it is not a xtrSense 4.6 issue.
kar0la420 - try and find the user's manual for your BT device online. Every headset is different, but on mine, the same button which is used to accept or initiate a call can be long-pressed to initiate pairing activity. You do that, and then perform a scan on the Eris to find the device and then pair to it.
eu1
