I've tried your forum recommended method for rooting my phone. I use a Macbook Pro, not a Windows PC (I have one at work, but I'm not the admin, and it's none of their business anyway).
Downloaded the files to a directory on my mac, extracted what needed to be extracted. Ended up with one executable for drivers, called Samsung_Mobile_USB_Driver_V1.3.800.0.msi,
and another directory with an executable for more drivers, called USB Drivers, and a directory for your root method, called one.click.root.exploitv2.5.5. The file run.sh was already executable for the owner, but I did chmod +x run.sh just for the record.
None of the driver executables will run on my mac. There's no program that I have that will open them. Not knowing what else to do, I ran the root method just to see what would happen. Below is the output to a
terminal:
dr-general-1-125
ne.click.root.exploitv2.5.5 hughbowen$ ./run.sh
Original one click made by joeykrim and one click installer made by noobnl and firon
busybox by skeeterslint
Press any key to continue...
Starting adb server
./run.sh: line 23: adb: command not found
./run.sh: line 26: adb: command not found
./run.sh: line 33: adb: command not found
./run.sh: line 35: adb: command not found
Phone is not connected. Press any key to continue.\n
I need help with this. I previously tried to use Z4root, another so-called
fool-proof method to root, and it didn't work. I posted a query to the Samsung Epic G forum earlier today, on that but when I look for it, I can't find it. I need this to use the app Copy Paste It, which requires root. I can't believe Android doesn't have this built into it.
Help please!
Best, Ferrel
terminal:
dr-general-1-125
ne.click.root.exploitv2.5.5 hughbowen$ ./run.shOriginal one click made by joeykrim and one click installer made by noobnl and firon
Starting adb server
Help please!
Best, Ferrel
