Root problems after rooting my xperia x10
Only the left light works between my 3 keys :/
Deleted bootanimation.zip but when I go to put a new 1 in there it says memory full :(
Help please.......
Hey,
I moved your thread to your phone's root section for ya! You'll get more exposure there! :)
Steven
Help please.......
Do you have room on the phone? Not the sdcard but the RAM.
If it was close to full during install it could have misse something during install. Have u tried to reflash reinstall after making more room/deleting apps off the RAM?
Same with the bootanimations...if it was close to full before putting them on there and u tried to install them it may have unpacked and installed half the stuff, then it got full.
Reflash and reinstall after making room if u havent tried that.
Sounds stupid but how do I reflash?
Here is the easiest way is listed in this GREAT post
http://androidforums.com/x10-all-things-root/272949-flashtool-guide-how-n00bies.html
WHAT YOU NEED:
Flashtool from HERE
X10i Generic
Generic version 2.1update1 build 2.0.2.A.0.24
X10a Generic
THEN
OPTION 1 - EASY WAY (*.ftf files)
1. Install Flashtool :p
2. Copy the *.ftf files that you `ve downloaded earlier to firmwares folder from Flashtool.
This image has been resized. Click this bar to view the full image. The original image is sized 873x316.
3. Click "Flash" button from flashtool and select the *.ftf file firmware and click "OK"
4. Relax and wait a while. When the proccess is completed you will get a popup message (don`t click on that!!!)
5.
PHP Code:
a. Unplug your USB cable from PC
b
. Power off your phone
c
. Press back button and keep your finger on button
d
. Plug USB cable to PC
e
. Check if the green LED appear
f
. On popup message press "OK" button
g
. When "Found at USB/........" appear on flash tool you may release "back button", sit down, relax and wait.
This image has been resized. Click this bar to view the full image. The original image is sized 945x570.
6. IF the "Start Flashing" message appear everything`s ok if not...repeat. Sitdown and relax (again :) )
This image has been resized. Click this bar to view the full image. The original image is sized 698x482.
7. When last message appear unplug/plug USB cable
