Definitely get on the phone to vzw...
In home screen, long press "menu" button (left of home), menu, settings, google now, theres an on/off switch at top right mate![]()
No. It takes you through a wizard when you first use Google search and asks you if you want to try Google now. Its off until this point
Thanks!Can i just add (if someone hasnt already) the samsung approved way of factory reset after an update
Status of "Unfortunately, the process com.google.process.gapps has stopped" AFTER Jelly Bean? - Android Forums at AndroidCentral.com
Post #3
Is this complete BS or is there any good reason behind all this battery stuff?
Thoughts?
(I didnt do it...maybe i should)
Good to know re: your instructions for turning it off - very helpful!
So I couldn't tell, but does Google Now default to being "on" when you update to JB? I just received my phone that had already been updated to JB and curious if that's why my battery life is low.
On a side note, I'll probably do a factory reset just to be sure since I just received my phone and could tell it was doing several updates while activating - it's hard for me to trust that everything works well when you inundate your phone/system with all of that at once....maybe it's just me![]()
Has anyone heard if Samsung is aware and is planning on addressing these issues?
I contacted support and did all of what they said but nothing has worked, in the end they said take it back to the place of purchase for it to get assessed, but I just know that will A. Take ages, and B. They wont find anything "wrong" as the phone works, its performance is just crap worse than my old P500.
Its a brand new phone (just over a month old now) and I don't want to void my warranty by rooting the thing which as far as I know is the only way to go back or get a stable proper version of JB working????
