Looked around didn't see anything here, but when I hook my DX up to my computer through USB it will vibrate saying it was hooked in, but it will not charge or show up on my computer at all. What am I doing wrong? =/
When you hook it up you should see the USB icon in the notification bar at the top of the screen. Pull the bar down and tap on the USB connection. You should than have 4 choices. Pick the one that is appropriate for what you want to do.
