Help Problems get Phone Audio to work with BT Headset
Hia84
Hey I have a problem with my HTC Desire S Just a while back The headset (SE HBH-DS980) just stopped working, when I try to connect it, it will connect to Phone and Media Audio but when I choose Phone audio only it will disconnect.
I have done a master Reset on the Headset and Paired it again to the phone. Can't figure out what's wrong with it, It worked just fine just a while back..wonder if it's since last update?
Anybody heard of this problem or had this problem?
only thing I could find was problem about music didn't play but you could talk and take calls just fine.
Thnks
Now I have tried to connect a bt headset mw600 to the phone didn't work either. I can't uncheck media audio. It only connects to media audio. When I tried to connect the headset to a HTC sensation it worked right away. The difference was that phone audio was "on top" of media audio. And the hs stayed connected. Can u choose which audio the phone should prioritize? I think everything got screwed up when the bt device tried to connect to the cars audio system. I have.done a reset on both bt hs but the phone stills priorities media audio and I can't uncheck that box because it won't connect then. Anybody have any ideas?
