problems playing downloaded movies...
i recently purchased tha huawei android phone and i would like to ask why when i download a video it will go to play but then skip thru the video and pause n play certain parts ..it worked when i first got it ,i must have downloaded a video that messed it up is there anything i can do ??
Welcome to AF.com. Which phone is it? It really depends on the phone you have. This is not a general Android issue.
What's the format and codec of the video? What bitrate was it encoded at? Resolution?
Have you tried rebooting? Do you have this problem if nothing else is running on your device?
Press and hold the power button till the boot menu appears, then choose reboot. Alternately, you can pull the battery, replace it and then power on the phone.
