andrewas316
I'm having problems with my beloved desire hd!
1st problem is it won't connect to my home WiFi it knows it should connect and says remembered network and full excellent signal but when I try to connect it says ....connecting.... Then disconnecting then scanning and back to disconnecting! Or it connects and and it says no internet connection but my laptop ps3 etc are all running ok?! Also it does connect to other WiFi connections I have saved! It's annoying even more due to the second fault!
I never get a 3g connection I get g, e(which is typically slow) and h in most places but then the while loading the web or Facebook twitter etc the 3g logo will show abs my connection will stop! I'm on Vodafone network in the uk
Has any one any ideas what could be causing these problems?
