Help Problems receiving and send text with pictures
Cooper13
OK I'm read a lot of other people who are having this issue but haven't seen the solution.
when i take a picture and send it to someone, it'll say, "sending" for up to 2 or 3 days sometimes. it takes forever to send a picture and they're not huge, say, 38kb.
when receiving some pictures, it says the message size and when it expires and that it's "downloading"
i went the support for AT&T. the guys is telling me that i can only receive and send pics to other phones that have 8mb cameras or higher? that seems crazy to me.
Yeah that customer service suxs sorry. check your messaging settings for
answers or ideas, could do a factory reset if you haven't yet?
Factory reset seems a little harsh for a minor issue such as that. I have the same problem from time to time on my Galaxy S2 as well. I notice that when it happens to me though, my bars are lower and my data speeds are most likely lower as well. Could be an AT&T problem, but my bet is that a lot of minor issues the Galaxy S2 has will be fixed with the ICS update... now we wait
I believe this is a problem with At&t's network, my Nexus One had the same issues. Would send people pictures and they would never receive it or I would never receive pictures from them. This is also now happening on my SGS2. When I originally had the problem I contacted the Nexus One support line (which at the time was run by Google and was fantastic) and talked with a rep for a few hours trying to rectify the problem. In the end they sent me a brand new Nexus One but to no luck.
Mine won't send or receive pictures at all unless I have the packet data feature turned on.
--Wag--
I have been having the same issue since the original galaxy came out, I pull the battery and that usually solves the problem.
Happens to me a couple times a year.
Hello,
I've noticed the same issue with my Samsung Exhibit II through Walmart's pre-paid plan with T-mobile over the last month or so.
The texted pictures used to work fine and all of a sudden every incoming text with a picture gives me only the file size and "downloading". Has anyone ever figured out a way to resolve this?
