Root Problems Rooting with ART Enabled
Shocky
Android Expert
So I enabled ART and lost root, tried two methods for rooting and neither is working now.
Anyone had any success?
What root app are you using? Also, I'm moving this into the All Things Root section :)
I tried a few, SkipSoft and one by WugFresh.
I just re-flashed the same firmware and kept my data and then root worked fine.
Art needs a little work anyway, a few apps didn't work and performance seemed about the same, it did load apps a bit faster though.
