Hi folks,
Newb' to the forum here.
Two issues I've had; one definitely not me, the other possibly me.
When trying to use any kind of word processing: texting, snote, an office suite, if I try and select an area for editing the little blue indicator goes nuts. It jumps around the screen, trying to follow my finger or the spen and then returns to the original position. It takes a while to select the correct area and it's frustrating.
My Note seems to be stuck on headphone mode. When I insert or remove the jack the little indicator appears, so it recognises something. However, I can only get sound when headphones are plugged in. Other than that, nothing; no music, alerts, alarms or ringtones. I reckon I could be the culprit though. The other day as I stood up, I walked away with my note on the desk but the jack plugged in. It fell but luckily never hit the ground, the inserted jack caught the fall, so I reckon that tug may have had something to do with it. I done something similar with a new laptop and the tug of the jack meant sound no longer came from the speakers, only the headphones. I removed all recent apps and done a hard reset - nothing. Luckily my carrier have agreed to send out a replacement as they deemed mine 'defective'. :stupido3: Obviously they aren't meant to be thrown around but they are also fragile to the extent that something like this could end up costly.
Anyway, if it's my fault then lesson learned. But that typing issue was still a pain in the crack! :hmpf:
Cheers folks
